Group: DynoMotion Message: 14497 From: Russ Larson Date: 3/17/2017
Subject: Re: Radius to end of arc differs from radius to start. [1 Attachment
The problem is when you go to N300 and just set that as the next statement you have not established your X coordinate.  You need to do RUN FROM HERE, not sure if they have that in KmotionCNC, I have that on my bigger machine.  Are you running the MACH3 front end of just Kmotioncnc?
Russ
Sent: Thursday, March 16, 2017 5:53 PM
Subject: [DynoMotion] Radius to end of arc differs from radius to start. [1 Attachment]
[Attachment(s) from g.astras@... [DynoMotion] included below]
I run this code with no problem in KMotionCNC. But when i try to cut only one hole, for example start from line N300 , by means of "Set Next Statement" i get the error "Radius to end of arc differs from radius to start" and the program stops.
How can i cut whatever hole i want in this program.
Regards.
Avast logo
This email has been checked for viruses by Avast antivirus software.
www.avast.com
Group: DynoMotion Message: 14498 From: geast1967 Date: 3/17/2017
Thank you for the reply.
No just KmotionCNC, no Mach3.
Group: DynoMotion Message: 14499 From: geast1967 Date: 3/17/2017
Group: DynoMotion Message: 14500 From: Shannon Davenport Date: 3/17/2017
hello g.astras,
I was having the same problem.  the issue was just what the error stated "beginning and end of arc were not exactly the same"  Tom added a tolerance parameter in kmotioncnc that fixed it.  its in the lower right corner of the trajectory planner screen  (Tool Setup > Trajectory Planner).  I set it to .005 and haven't had an issue in 6 months.
HTH, Shannon
On Thu, Mar 16, 2017 at 5:52 PM, g.astras@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Regards.
